Can anybody explain what is happening? I am driving along and go to change up a gear but instead of going from 4th to 5th it jumps to a lower gear.
The change down is violent but there is no crunching or anything. It is as though I had chosen the wrong gear, but I had no choice in the matter.
This only happened 2 or 3 times yesterday, and I didn't have time to make all the observations and analysis I would like to have done. Especially as this problem occurred in a busy traffic situation causing people following me extreme alarm, as presumably no brake light was visible to them when I slowed down so fast.
All clues as to what to look for will be welcome.
C5 X7 Manual gear problem
mypinknee
- (Donor 2021)
- x 11
My other car is a 2cv
- x 6945
Re: C5 X7 Manual gear problem
Please pop your VIN here so I can check the exact box you have and for any applicable any TSBs.
- x 1938
I'm unclear whether this is a manual gearbox or an auto gearbox used in manual mode.
mypinknee
- (Donor 2021)
- x 11
mypinknee
- (Donor 2021)
- x 11
VF7**************[VIN obfuscated, can be read by forum staff]GiveMeABreak wrote: 15 Dec 2019, 11:38 Please pop your VIN here so I can check the exact box you have and for any applicable any TSBs.
- x 1938
So it sounds like when you're going over from the 3rd/4th plane to the 5th/6th plane it's actually staying in the 3rd/4th plane and you then select 3rd instead of 5th.
Does it feel as though you're going into the 5th/6th plane, i.e. is there some resistance, or is it just a "looseness" moving over?
paulmac1978
- (Donor 2017)
- x 3
I’ve had a similar issue on a C5 X7, it was the ball joints where the gearbox cables join the gear linkage. They needed cleaned and greased. One was seizing/sticking so the wrong gear was being selected.
Paul
Citroen C5X 1.6 Puretech 180
mypinknee
- (Donor 2021)
- x 11
There was no resistance at all and it frightened me nearly to death!Paul-R wrote: 15 Dec 2019, 12:14 So it sounds like when you're going over from the 3rd/4th plane to the 5th/6th plane it's actually staying in the 3rd/4th plane and you then select 3rd instead of 5th.
It only happened three times on my way out. The return journey was fine and the fault did not reoccur.
- x 6945
So 6 speed (ML6C) fitted on this model.
Possible symptoms:
There is a check you can do:
Possible symptoms:
- Impossible to engage gears
- Changing gear difficult
- The gear engaged is not one wanted
- No drive of the vehicle
- Clutch release difficult or impossible
- The clutch pedal remains on the floor(Permanently or intermittently)
- The clutch pedal is hard or soft
- The clutch pedal does not rise completely or does so in 2 stages
- Brake fluid leak (Clutch control)
- Oil leak from the gearbox
- Engine stopped: Declutch and keep the clutch pedal pressed down during the operation
- Carry out one of the difficult gear engagements (whichever one you had the problem with - i.e. 4th to 5th)
- Stay declutched
- Move the gear lever to the neutral position
- Carry out the same gear engagement (whichever one you had the problem with - i.e. 4th to 5th)
mypinknee
- (Donor 2021)
- x 11
Yes - 6 speed. Thanks. I will try out your last suggestion.
I am sure it is well beyond me to fix, but as ever I appreciate your advice.
My only comment is it is not difficult to change gear in any way.
mypinknee
- (Donor 2021)
- x 11
Just tried the de-clutch test and there was no problem.mypinknee wrote: 15 Dec 2019, 13:37 Yes - 6 speed. Thanks. I will try out your last suggestion.
- x 6945
Ok so if there is no problem with that test, then you are into the realms of checking the travel of the hydraulic clutch control slave cylinder, synchromesh and other tests involving the clutch and flywheel. So see how it goes and if you get persistent issues, keep a record of the issues (which gears are difficult to engage, any issues selecting reverse, does it jump out of gear, etc,) so you can provide as much detail to any garage / dealer if necessary.
