My 405 1994 1.9 diesel, saloon, has an irratic fuel gauge. 1 minute it's 1/2 full then 3/4 then 1/4 full!!
Does anybody know what are the expected resistances are from the fuel gauges sensor, I can roughly judge the expected position from filling the tank from the yellow 'fuel low' warning light. Or is there another check possible??
Is there a check possible on the indicator gauge in the instrument panel.
THX
Ash
[8]
Fuel gauge crisis!!
Peter D
VisaGTi16v
DLM
If it's like the Citroen BX with the same engine (which I strongly suspect it is) then these senders do wear with age and get pretty unreliable. I'm relying on my yellow warning light nowadays as the only reliable indication of what's in (or not in) the tank.
As a first non-invasive check I'd give the contacts at the sender a good cleanup (underneath the back seat), before proceeding any further. If anything wet has ever got underneath the seat it doesn't do these contacts any good...
