2005 Renault Scenic 1.5 Dci
Trying to figure out if they blooming thing has a DPF or not, I can't really see under atm.
But did this version even come with a DPF?
Was looking at TRIPLE QX Fully Synthetic (Low Saps C3) Engine Oil - 5W-30 to service with but obviously not needed if no DPF.
It seems to take a massive variant of oils according to the manual and Euro car parts etc.
There appears to be a leak of oil sprays small amounts out near the turbo flex pipe, looks worse then it is as it doesn't loose to much oil over a four months its lost about a half reading on one of the measurements on the dipstick, I'd assume that's less then 150ml (going by the dipstick usually being about a litre). Is it likely a seal, or the EGR blocked? Should oil even be near there?
It's had a new turbo at some point or a refurbed one before we bought it, have no history with the car.
Any ideas would be helpful. If it's easier just to replace that area then cool.
Correct Oil 1.5Dci Reanult Scenic 55 Plate & Oil Leak from Turbo intake?
Adam2050
