EGR valve …….. To clean or not to clean ?
jml
Locked user account
x 37
Unread post by jml »
Generally I’m very keen on preventative maintenance and maybe that’s part of the reason why my C8 2.2 HDI 173 has got to 160,000 miles with very, very few problems. However, now I can’t quite make my mind up whether I should attempt cleaning my EGR. So, why the dilemma ?
Well, I’ve almost always used premium fuel, which is claimed to have more detergents, and when I cleaned my DPF, at around 120,000 miles, it really wasn’t dirty at all. I’ve always used Total’s Quartz Ineo ECS which should have helped keep things clean. The car runs well and I’ve kept a detailed check of the fuel consumption throughout it’s life and it is actually slowly improving. My DPF additive didn’t need refilling until over 140,000 miles, so everything seems to point to the fact that all’s well, so maybe I should leave well alone.
But, as mentioned, I like to try and prevent any problems before they occur so should I remove the EGR valve to clean it ? Well, have you seen the layout on the C8 or read the official process ?!! Because it is pretty complex, I’d be a little apprehensive that, in removing the EGR, there’s a chance that I may disturb something or cause some other problem. Of course, I could use a spray cleaner like Wynns, but with the instructions advising “During the spraying, the rpm can go up or down. Diesel knocking can increase” I’m rather nervous about using that.
So, preventative maintenance or ‘If it ain’t broke. Don’t fix it’ Any thoughts folks ?
Julian Leyton (RIP) 2023
x 2005
Re: EGR valve …….. To clean or not to clean ?
Unread post by Stickyfinger »
‘If it ain’t broke. Don’t fix it’ is my vote.
Nothing bad will happen if you leave it other than -maybe- having to do it at some time ahead.
jml
Locked user account
x 37
Thanks Alasdair.
Having just re-read the Citroen instructions I’m, more than ever, inclined to agree with you !
Out of interest, does anybody have experience with the Wynns’ EGR aerosol cleaner ?
Cheers
Julian
Estately
x 22
Unread post by Estately »
I know where you are coming from re EGR removal particularly if all seems well with that component.
I have used the EGR aerosol but on two MKII 2.0L HDi C5’s, for no other reason than they had both covered about 120k miles at the time of use and there was no change in performance as a result of the treatment either then or later. About the same time a friend of my son’s Citroen van with the 2.2L engine had the EGR changed under warranty and he brought the EGR for us to see which was coked up solid. He is a very spirited driver and the van was always well loaded.
On the 2.0L HDi engine it is possible to loosen the clip on the inlet pipe work on top of the engine and temporarily fit the plastic red extension pipe that comes with the aerosol to give a squirt into the inlet as close to the EGR as possible and obviously clear of the air filter.
I think the EGR treatment was a Forte product, It was sprayed in with the engine up to temperature running between tick over and 1200 rpm. The engine does start to run roughly and stutter at which moment I stopped spraying until the revs returned to normal before repeating 3 or 4 times. I don’t think much of the can’s content was used.
As an aside, when the cam belt was changed the diameter of inlet ahead of the inlet valves was considerably reduced by a build up of carbon.
Hope that helps.
Andy.
If it can happen it will.
van ordinaire
(Donor 2017)
x 402
If you can't see it to check if it needs attention & everything suggest it doesn't then don't - then don't.
As for the immediate effects of using a spray, when I did the C15 (at, I suppose, 205,000) because its appearance was akin to the inside of a sump, it raced for a few seconds &, presumably 'til the cleaner was consumed, & immediately settled back down to an even tickover.
Now curious as to whether it is any part of a service schedule.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
jml
Locked user account
x 37
Thanks guys for all of your thoughts.
As I mentioned, I've almost always used premium diesel - It hurts at the pumps, costing about £7 or £8 extra for every fill, and I do about 25 fills/year and I've often wondered if I was just pouring money down the drain. However with the long life of my DPF additive and a clean filter I'm just hoping that it really has helped to keep things clean and keep my engine running smoothly - let's hope that's not just wishful thinking ? :?
Mind you, I was talking to the Editor of Diesel Car magazine the other day and he felt that using one of the additives like Millers Ecomax at each fill up would probably have the same effect as using premium fuel but at much lower cost. However I did use that for a while earlier in the car's life and it STANK :o and the smell seemed to hang around for ages.
Cheers
Julian
