Headlight not working - 1 side
hu8ix
Unread post by hu8ix »
Hi.
I just got a 1994 S1 with what I thought was a blown dipped light bulb on the driver's side - all is well with the passenger side and other lights (incl. indicator and dims)
I changed the bulb, tried to re connect the wires, and even reconnected the main wiring loom after blowing some air thru- connector but to no avail
Any tips will be appreciated :)
H.
x 1486
Re: Headlight not working - 1 side
Unread post by xantia_v6 »
Is this your Xantia? I think that there may b a separate fuse for each headlight. Is high beam OK?
x 1240
Unread post by Peter.N. »
If its not a fuse it will probably be a wiring fault and by far the easiest way to resolve that would be to fit a relay connected to the 12v supply and energised by the voltage of the lamp that does work, I had to do this on an Peugeot 406. But thoroughly check all the fuses first.
x 3298
And don't just look to see if a fuse is blown; make sure the areas of contact (on the fuse AND the holder) are clean. I had an issue in the past with a rear wiper working intermittently (until it finally stopped). I looked at the relevant fuse, and while the wire looked good the contacts looked dirty. I used some contact cleaner, and then plugged/unplugged the fuse several times. After that the rear wiper worked properly.
van ordinaire
(Donor 2017)
x 400
AND, if it is a fuse, that's not likely to be the cause - but the effect.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
hu8ix
Excuse the delay in replying. I crashed the car the same day I posted this. Brakes didn't work. Probably an LHM airlock.
x 3298
Ouch! :shock: I hope you are OK, and the car is repairable?
x 5690
:cry:
