STP Radiator Sealer
aneesh84
- x 29
STP Radiator Sealer
I had been losing antifreeze from my C5 for quite some time at a slow but constant rate. It seemed to be coming out of water pump gasket. The pump was replaced only 3 years ago.
A mechanic advised me to try STP Radiator Sealer. I was initially hesitant since I had read warnings about it plugging the heater matrix. Nevertheless I tried this one.
And its been more than a month and I must say I am very pleasantly surprised. The leaking has stopped, and my heater works perfectly. I dont know about any long term implications, but as of now I am very satisfied with the product.
Would like to hear experiences from others if they tried this or similar products.
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
van ordinaire
- (Donor 2017)
- x 402
Re: STP Radiator Sealer
Lots of dire warnings about these products (as with any snake oil) even the GM factory fitted Barr's Leaks pellets! However, my friendly local mechanic said he'd only use Wynn's, as the only such product known to work. Can't speak for it myself, although may be able to later as found some in a cupboard which will probably go in the red Cherokee, which loses a little coolant although has no apparent leeks.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 2005
The "problem" with sealers is for cars with the very fine water/oil coolers and/or the equally troublesome gearbox oil/water heat exchangers.
aneesh84
- x 29
Which cars would that include? The C5?Stickyfinger wrote: 16 Nov 2019, 19:36 The "problem" with sealers is for cars with the very fine water/oil coolers and/or the equally troublesome gearbox oil/water heat exchangers.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
- x 2005
Yes, and Xantia. Some members report blockages in their cabin heater as well.
- x 3306
As far as I can recall, the only sealer that is recommended is Forté Stop Leak. Valeo (who are an OEM) require you to use it (for warranty purposes) if you are replacing the heater matrix.
- x 2005
- x 1056
I have used K seal many times with great success.
Subsonicnat
- x 11
Iwas Always led to believe these were a Get you Home Solution,, Not For a Permanant Solution.. I believe you are always asking for trouble if trying to use it as a permanant Fix.
Heaters are very prone to block, Hence overheating and should the worst happen blown head gasket and worse still,Bent conrods..
Get you home,Yes,, Stop gap, Yes..
Solution:: Fix it properly,, Will, work out cheaper in the Long Run.
aneesh84
- x 29
There are warnings like you mention all over. But these solutions could have evolved over the years. For me STP radiator sealer has worked fantastically over the last two months, as for many others. So I created this thread to share real experiences not hearsay. I have not seen one post from someone who used these sealers in recent years and had an otherwise clean system and faced blockage issues.Subsonicnat wrote: 19 Nov 2019, 19:35 Iwas Always led to believe these were a Get you Home Solution,, Not For a Permanant Solution.. I believe you are always asking for trouble if trying to use it as a permanant Fix.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
van ordinaire
- (Donor 2017)
- x 402
That's a very worrying statement - on several levels!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
aneesh84
- x 29
LOL! I am sure he means "used on different cars". I guess we should be open to hacks and improvised solutions, sometimes they are well worth the cost and effort they save.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
van ordinaire
- (Donor 2017)
- x 402
Even if you're right - he's been very unlucky!
No problem with improvisation - but K-seal's touted as a permanent repair, whereas it's known to have caused permanent damage!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
aneesh84
- x 29
The customer reviews seem quite positive: https://www.amazon.com/K-Seal-ST5501-Pu ... merReviewsvan ordinaire wrote: 20 Nov 2019, 19:39 Even if you're right - he's been very unlucky!
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
van ordinaire
- (Donor 2017)
- x 402
They do indeed, but I can vouch for the fact it's about as useful as Holts Radseal & evidence of its use will lead to sucking of teeth by any mechanic, dire warnings/horrific anecdotes &, possibly, a refusal to work on the vehicle.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
