Hi to all,
I have just bought a 2015 Nemo with no service history,
The van shows service =0 in the menu.
Can anybody advise what this means please.
Many thanks
Service on Nemo (help)
- x 6957
Re: Service on Nemo (help)
It’s likely to be that the due service date has been and gone.
Lochryan
Thanks for youre reply Marc,
I was thinking that but can't understand why the service light isn't on.
Don't know whether to get it serviced by my local Tyre and Exhaust garage or drive 120 miles to the dealer. Do you think the service light will come on at any point if i gets it serviced locally?
Cheers
Cheers
- x 3306
Normally the service light is only lit if there is a serious (enough) problem to light it.
Lochryan
Does that mean the service light will never come on unless i have a problem?
- x 3306
If you mean the Engine Management Light (EML) this will come on when you turn the key in the ignition (but not to the point where you are starting the engine), and it should then go out within a few seconds of the engine starting.
Lochryan
Sorry for not being clear i mean the routine service light.
