C4 1.6hdi 2007...Timing Kit
Doo
(Donor 2022)
x 121
Unread post by Doo »
Hi all, sorry not been around, haven't been feeling the best.
Soon be doing wife's car which is starting to rattle on light throttle and I suspect it's the timing chain tensioner.
I have a DAYCO belt kit, BERU glow plugs and have yet to find a timing chain kit.
Which one is recommended by the forum?
I have done many timing belts in my time, including the 1.6hdi, but never a chain.
Would it be easier to remove the engine& box from the car so access is better while on a bench or should I struggle with it in the engine bay?
I was going to do an oil & filters change and hope the engine will survive the winter and do it in the spring.
Anyway, I figured pulling the engine out and replacing loads of bits before she reaches the 100k mark.
Thoughts??
Thank you. Doo.
Has anyone seen the plot? :?
Doo
(Donor 2022)
x 121
Re: C4 1.6hdi 2007...Timing Kit
I'm guessing no one has tackled the chain then?
Reason I'm concerned is because my friend had an 06 model with a pronounced rattle which got worse over a couple of months.
He drove the car hard with over 100 mile journey twice a week and it was rarely under 100mph with harsh acceleration.
Anyway, it started off with a quiet clatter which got worse as the weeks progressed until it sounded like all the Dwarven Blacksmith of Svartalfheim working while high on drugs :lol:
When it let go, quite spectacularly by all accounts, the valves were hammered into the head (and pistons) so hard it would have been impossible to remove them! :shock: I saw the aftermath :?
So, while wife's engine is in otherwise good shape, it's on 88k and climbing so I wan't it done because it's a great car. I love the shape of it, those lines, the front end so elegant and functional 8-) It's nowhere near as comfy to drive as my Range Rover, but the handling is awesome. You can chuck it at a corner and it flows through it whereas the Range Rover rolls like a ferry in a storm :-D
x 1484
The chain is not a service item, so there won't be a kit as such - I expect you will have to go to the dealer. There have been a couple of threads on here - one where the chain had chewed into the head, and the other where it jumped a tooth during a belt change (do NOT turn the engine backwards!!) causing all sorts of the mayhem. I suspect both were by lighty... The chain is a bit a mare, as you have to remove the upper part of the cam carrier, which involves removing the injectors, which may or may not want to come out! I would only tackle it if you were absolutely sure it was necessary. The chain is available from Citroen, with the tensioner, for£118 - part no 816J1 (for a 110 HDi - post up the VIN to check this is the right number!)
Edit - quite a few kits on ebay around £75 - 80 against that part no.
Doo
(Donor 2022)
x 121
RichardW wrote: 04 Nov 2019, 20:59 The chain is not a service item, so there won't be a kit as such - I expect you will have to go to the dealer. There have been a couple of threads on here - one where the chain had chewed into the head, and the other where it jumped a tooth during a belt change (do NOT turn the engine backwards!!) causing all sorts of the mayhem. I suspect both were by lighty... The chain is a bit a mare, as you have to remove the upper part of the cam carrier, which involves removing the injectors, which may or may not want to come out! I would only tackle it if you were absolutely sure it was necessary. The chain is available from Citroen, with the tensioner, for£118 - part no 816J1 (for a 110 HDi - post up the VIN to check this is the right number!)
Thank you for that. So I may be just as well to pull the engine and do a full rebuild then. I'll do the clutch while I'm at it.
Looks like next year going to be busy :-D
