Hi
Is changing a rocker cover on a 2009 1.6 Hdi an easy job? https://rover.ebay.com/rover/0/0/0?mpre ... 2683083611
Looked on videos online and it looks easy, but am surprised some garages have told me it is a big job. Any advice much welcome
Louis
Changing 1.6 Hdi Rocker Cover
- x 1484
Re: Changing 1.6 Hdi Rocker Cover
Yes, changing that bit it easy - taking off the bigger cover that covers both cams is much more involved - not least because you need to remove the injectors.
ldare2000
- x 4
2RichardW wrote: 31 Oct 2019, 07:18 Yes, changing that bit it easy - taking off the bigger cover that covers both cams is much more involved - not least because you need to remove the injectors.
Hi
Thanks for the reply. 2 injectors may need to come out anyway as they are chuffing. What's the bigger cover called please?
Ta
Louis
