Aisin C5 gearbox parts check
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi all, sorry for starting a new thread.
Can someone tell me if there are any differences between the Autobox in a C5 X7 2.0hdi (163HP RHH) and the 2.7 hdi?
many thanks
John
Xantippa
x 29
Re: Aisin C5 gearbox parts check
Unread post by Xantippa »
Yes they´re different. At least final ratio isn´t same with different engines.
jgra1
(Donor 2021)
x 36
dam,, thanks Xantipippa..
x 6955
They are different John - both in part numbers and gearbox markings:
Yours (2.0 HDi DW10CTED4)
Part number: 2231L9
Gearbox Type GF13
2.7 HDi: Part Number: 2222ZQ
Gearbox Types: GG05, GG07, GG09
There are differences in converter torques and speeds in different gears, changing down and final drive ratios.
x 1438
Unread post by xantia_v6 »
4 and 6 cylinder versions probably also have different casings to fit the engine block bolt patterns.
jgra1
(Donor 2021)
x 36
thanks all :)
