Hi Jon,
I need to change the cam belt on my '96 Activa (RP 7168) very shortly but could you please confirm that these items, for the 2.0 8V Xantia, also suit my car:
Timing Belt N13119
Belt Tensioner N13160
Also, since the counter service at Andyspares is no longer available, do any of the GSF branches in Reading/Farnham have a French bias with regard to the stock they carry?
Thanks very much,
Simon.
GSF PART NUMBER CHECK
Jon
Yes, the timing belt and tensioners are the same as on the standard 2.0 8v. I'm not in work just now to check if thoses branches have stock, but they should both have at least the timing belt.
If you don't mind venturing a bit further afield the Heathrow HQ is where most of the Andyspares stock and staff are, they will have good stock there of what you need.
surfer
