relay 2,2 hdi 2011 bad idle
Ukozwhit
hi all , ive a 2,2hdi relay 108k , drives perfect but idles bad , ive had an injector replaced which was faulty , cleared the codes , and its still no better ,its had the hdi valve replaced {not the pump} by previous owner , any thoughts guys ?
- x 3306
Re: relay 2,2 hdi 2011 bad idle
Hi, and
to the Forum. The only advise I can offer you is to post up the VIN here (which will be obscured so only forum staff can read it) so a Moderator can look it up and see exactly what she had when she rolled out of the factory. Then they can know what you are dealing with.
I don't suppose you know what the codes were before you cleared them? That could also help with the diagnosis.
Ukozwhit
hi thanks for the reply , we had no 1 injector fault , and po963 pre post heating relay . heres my vin VF7**************[VIN obfuscated, can be read by forum staff] hope this sheds a little light
