I have been having a few cold running issues with a Relay for a while and now the cold weather is back the problems are getting worse again. Long story short I want to put some Liqui Moly cleaner through the injectors in case it is a simple fix before I dig deeper. If I run the van out of Diesel, how much fuel is still in the tank i.e. below the pick up?
What I am looking to do is add the Liqui Moly straight to the tank, run the van on idle for a bit and then change the fuel filter and top up with fresh diesel. The key to it is how much is left after it runs empty. If there is still a gallon left then it will dilute the Liqui Moly but if there is only a litre or so left then 5L of Liqui Moly will will be quite potent.
Thanks.
Citroen Relay fuel tank
- x 1751
Re: Citroen Relay fuel tank
Few of the normally available diesel system cleaners are meant to be used neat, or at high concentrations - although some 'diesel improvers' being sold have been found to contain mainly . . . diesel!
LiquiMoly produce some effective products. Which of their cleaners were you looking at?
Two of the best cleaners-fuel improvers are meant to be used at a dilution of 1:200 for a remedial clean, and 1:1000 for regular use. These are washed into the tank as part of refuelling.
