Fred’s passenger exterior door handle has become a bit sticky. My mum can’t work it, I have to open the door for her.
I just hold the handle up and it takes a couple of seconds, then it opens.
I wonder if there’s a fault with the handle? The door opens normally from the inside.
(I’ve had another make of car where the handle cracks inside)
Ta.
Sticky door handle - Xantia
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 1438
Re: Sticky door handle - Xantia
I have not heard of that problem, but think it is more likely to be wear or lack of lubrication in the latch mechanism.
Jaf
- x 42
Thank you! You were right, lack of lubricant in the catch. Gave it a spray of oil to clean it out, then some spray grease and it works perfectly.
In my defence, the one time I greased the drivers door years ago because it wouldn’t close properly made it far worse. Had to clean it all out again.
