Citroen c3 picasso no power
SeanDuffy
Unread post by SeanDuffy »
I have a 2016 c3 picasso 1.6 blue hdi with 40k on it, car just suddenly lost all power an now its slow to rev up an gets very knocky the higher ur rev it, no fault codes stored in the vehicle an ive replaced the fuel filter an got the injectors tested an alls ok. Also removed exhaust to make sure its not blocked an also removed egr pipe from intake but still has no power, any solutions?
x 6955
Re: Citroen c3 picasso no power
Have you ensured it has plenty of Adblue? Any fault codes or warnings?
Ge best thing you can do is get it diagnosed to read the fault codes
x 3299
Hi, and :welc: to the forum.
Might I also suggest you post up the vehicle VIN (which will, for security reasons, be obscured so only forum staff can read it) so that a Moderator can then look up your C3 and see exactly what it had when it rolled out of the factory.
x 1929
Unread post by Paul-R »
GiveMeABreak wrote: 30 Sep 2019, 23:33Ge best thing you can do is get it diagnosed to read the fault codes
OP says that there are no codes stored.
SeanDuffy wrote: 30 Sep 2019, 23:10... no fault codes stored in the vehicle ...
But the question is what code reader was used to check for faults. If it's a basic one then it may miss specific manufacture codes that a high end reader, or a proper Diagbox, would find.
@SeanDuffy What code reader did you use?
x 6955
He didn’t mention a code reader at all and some refer to fault codes as EML or dash warnings.
There will be a 99.9% likelihood of a fault code for this sort of problem, but agreed it does need a decent compatible diagnostic tool to be able to read them. Ideally Diagbox.
SeanDuffy
Ive used snap on an launch on it an still no codes
