2011 508 Sedan rear suspension diagram
cornesoutafrica
x 9
Unread post by cornesoutafrica »
Hi everyone
I am looking for a rear suspension diagram for a 2011 508. the right rear wheel seems to have uneven wear. It is for a friend's car, so it isn't with me but I want to see if the suspension got bushes which may wear out.
Any help will be greatly appreciated
Regards
Corne
x 6962
Re: 2011 508 Sedan rear suspension diagram
Hi Corne - we'll really need a VIN as even going on the first generation of these there are several systems available (Hybrid Traction Train, Pseudo Macpherson etc.)
cornesoutafrica
x 9
Hi Marc
Will try and get it. A quick question, is there any similarity between the 508 suspension and the C6's Suspension?
x 6962
No, none Corne. The variant on some 508s was simply a strut with a supply of fluid to firm or soften the ride - it was not hydractive at all.
cornesoutafrica
x 9
Hi Marc
Not even the physical setup, meaning the bushes and bars etc? For some reason thought there are quite a bit of similarities on the suspension setup, apart from the hydraulics ofcourse...
x 6962
I'll really need to go by the VIN because there are 2 variants (soon to be 3 with a new version for 2019) and the setups are quite different, so the sooner you get me that, I'll be able to let you know what's what Corne.
cornesoutafrica
x 9
Hi Marc
Got the VIN hope it is correct...
x 6962
Ok, if you are talking about the rear multilink setup it is the same as the C6. However, although the parts look indentical and most have the same part numbers, there are subtle differences on some of the components like the nuts which are different sizes - so make sure you get the right part.
These are from the 508 for the VIN you supplied:
Table ATable BTable C
cornesoutafrica
x 9
Thanks Marc
I appreciate it. Think the problem might be identified, will get correct bushes
kind regards
Corne
x 6962
If you need part numbers - let me know table A, B or C and the item number.
