Hi All
I have a 59 Plate C4 Grand Picasso 1.6 Diesel which has been badly looked after and I don't think has been serviced for years and years. The engine is quite noisy,noiser than others.
Normally I used fully synthesic oil from Home Bargains but I guess this cheap oil has less additives.
Is there an oil out there that genuinely is worth paying extra for and what would be recommended for trying to proling the life of a badly treated engine?
Ta
Louis
Oil Advice
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Oil Advice
Look here on our Wiki.
https://frenchcarforum.co.uk/wiki/Citro ... arbox_Oils
You have a DV6TED6 1.6 engine with diesel particle filter. Therefore you need a low SAPS (prevents less ash entering the exhaust and therefore prolongs emissions equipment life.
So you really want a fully synthetic 5W30 oil for this climate and engine.
Re: Oil Advice
Hi Marc
I appreciate your time in replying. Out of the Total Quartz range which offer 5w30 what I am not sure is which is the 'best' for a worn engine? Looks like there are 2 or 3 options?
Kind Regards
Louis
Kind Regards
Louis
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Oil Advice
Total change their names frequently, Quartz INEO ECS 5W - 30 is one of the newer ones. However getting a fully synthetic is what’s important as they are non mineral oils and are loaded with additives for better lubrication, wear protection and detergents.
But the point is that if the damage is already done to the engine, then there’s not much more an oil can do as it’s there to help reduce damage in the first place.
I think the key is more frequent oil and filter changes about every 6 thousand miles might help. I wouldn’t get too hung up on the brand at this point, the correct spec and grade are what is important and the frequency of changes.
- My Cars: 2004 c5 2.0 hdi 138. *gone*
1988 pontiac firebird.
1996 1.8 8v xantia auto. soon to go .......
1999 2.0hdi xantia estate - x 16
Re: Oil Advice
Change oil now and in three months with filters and it should be good yearly from there .
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
Re: Oil Advice
Never been convinced about these extended oil change intervals (but, never had anything new enough to run on synthetic)
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
