Need advice Bipper 1.3 diesel van
Took van out to collect Mrs started fine
Came home
Tried to start again ignition lights on
Pos 1 and 2 fine. Turn to 3. Nothing
Would not start. But did on bump
But yellow triangle light came on and battrey light
Stopped then re bumped battrey light off
Triangle on
Took to garage
They said alt not charging
Replaced
Starter checked
Still nothing at position 3.. dead
Now they have ignition barrel in bits
Anyone know the problem
Please help
Bipper starting problems
- x 1056
Re: Bipper starting problems
Was there charge getting to the battery with the engine running or not?
If the starter isnt turning you need to check that there is a power supply to the solenoid when turning the key to the start position & that there is a sound earth to the engine block.
If it wasnt charging & also not cranking the engine the common thing to both these faults at the same time is an engine earth issue.
nickrob
Charging after new alt fitted yes
14 amps
Sure they said there was no power to starter
May of miss heard tho
They think its problem with ignition
Yet key lights up all lights
Just won't start
Will relay your thoughts to them
14 amps
Just won't start
- x 1056
Should be a fairly simple fault to diagnose, check for a crank feed at the ignition switch, if no crank feed at switch then the switch is faulty. If there is a feed there you need to trace the wire from the ignition switch to the starter.
Does the engine start if power is supplied direct to the starter motor solenoid?
nickrob
Sorry
Don't know answer to that
Tried to ring
No reply
Will update tomorrow. Ty
Tried to ring
No reply
nickrob
You were right Wheeler
Broken wire
But does require a new. Second hand ignition barrel
Can't just work out how to change chip
Only got one key which is non central locking... Does not split.. Not even got elec windows lol
Basic standard
Broken wire
Basic standard
alpinesprite
- New User
Hi all thought I would share my starter problem.
2012 Peugeot Bipper van 72k.
Random starting problem.
I would rock it in gear and sometimes this worked.
I would tap engine block with a hammer sometimes this worked.
In the end wouldn’t start at local tescoes.
RAC man jumped it and told me my starter motor was on the way out.
Got a quote of £260 to replace it.
Brought one myself £116.
Was a complete git to change mostly from underneath and used a mirror. (Remove 10mm bolt from right of bracket underneath and it bends out of the way allowing motor to drop out).
Van was the bloody same. Would not start.
Turned out the engine earth was corroded. Simple fix now starts on the button.
Anyone need a spare starter
