HDI TIMING BELT
thomas
HDI TIMING BELT
Unread post by thomas »
Can anyone supply me with details for replacement of timing belt on 2,0 hdi 110. fitting instructions and are any special tools required? I think I should replace waterpump and guide pulleys/tensioner at same time.
monkeyman
Unread post by monkeyman »
Hello!
I can supply you with infornation on doing the belt. It won't be until wednesday evening at the earliest as you proberly would like a picture to see how everything is laid out. The tools needed from memory are 2 timing pins (the pump doesent need timing) and a 'Seems' gauge to adjust the tension. The belt gets changed at 100,000 miles.
