Hi there .
Are there any members within a close proximity of stoke on Trent. I have just PM d a member on the lexia Map but it appears they havnt been active for a while so may not have revieved the message.
Basically I have a 2007 1.6hdi xsara picasso. I'm having ABS issues, and although braking is still ok, I'm getting the warning light. I also have the MIL light on from an old code which I cannot resolve. Any help would be greatly appreciated. The MIL originally illuminated because of Glow plug (since rectified) and EGR issues since replaced but the light is still on. It may be a matter of just clearing tue codes but who knows.
Like I said, any help would he greatly appreciated I'll add the remaining code to this post..
Many thanks.
John Brassington
Lexia in Stoke on Trent
thebrasso
Re: Lexia in Stoke on Trent
The code is P2670 maunufacturer undocumented code. But all other codes that were previously there have now been cleared, so I'm guessing lexia might be able to shed some more light to this and the ABS errors.
The original codes were originally diagnosed by a mechanic friend with a snap on diagnostic. They were all cleared except for theP2670..
Many Thanks
Many Thanks
- x 5671
Have you looked on this map?
A bit thin on the ground in your area
ekjdm 14 is about the closest known active member.
thebrasso
Looking on the map, harryp is quite close too. I'll look if he is still ana active member
Skull
- (Donor 2026)
- x 379
That map looks a bit like the Xantia's on the road map
Gary
Gary
