Citröen bx fault codes?
gamefreak26
Hey. Is It possible to read fault codes on a citröen bx. Its been having some idling issues when cold so id like to know wheres the problem if it can tell me.
- x 1056
Re: Citröen bx fault codes?
It will depend on what injection system is fitted, you need a 2 pin adapter for the diagnostic, the plug should be green (i think) & located in the under bonnet fusebox.
gamefreak26
Theres only a 3pin connector that i could find
