C4 2007 AC
Post your Cit/Peu/Ren air conditioning queries or advice.
Doo
(Donor 2022)
x 121
C4 2007 AC
Unread post by Doo »
I probably know the answer, but I'll ask anyway....
2007 1.6hdi SX.
Topped up AC and it barely lasted a day. That was 3yrs ago.
Being a black car, it heats up something rotten in the Scottish summer...but that half day each July is a lesson in driving naked and trying to avoid wasps while windows are open :rofl2:
My question is, I didn't see any obvious signs of a leak either at the condenser nor anywhere else for that matter.
So is there a common point in these cars that a pipe rots or a union comes loose or could it simply be the compressor isn't happy (although there is no noises suggesting it's gubbed).
Changing the condenser is a piece of cake, but I don't want to do that to learn there is a hole in a pipe hidden under some bit of plastic at the business end of the engine #-o
I just changed the condenser on the Range Rover and the whole job took 40 minutes. It took longer to re-gas it :roll:
Thanks all :)
Has anyone seen the plot? :?
x 6963
Re: C4 2007 AC
Leaks are notoriously hard to localise - even with a dye. It took 4 trips to my dealer before they found the leak (top of the condenser). But shortly after, it crapped out again and needed a new compressor - probably after all the filling and leaking / filling leaking - so probably was short on oil and damaged the compressor.
Doo
(Donor 2022)
x 121
Re: C4 2007 AC
GiveMeABreak wrote: 11 Sep 2019, 15:07 Leaks are notoriously hard to localise - even with a dye. It took 4 trips to my dealer before they found the leak (top of the condenser). But shortly after, it crapped out again and needed a new compressor - probably after all the filling and leaking / filling leaking - so probably was short on oil and damaged the compressor.
Spookily enough, that's where the P38 condenser goes. 8-[
There is foam at each end of the top of the condenser (well, actually on the removable panel, but it sits on the condenser) which I think holds all the cack thrown up off the road (salt in winter) and it rots the corner of the thin aluminium of the condenser.
Must be a problem for lots of vehicles. I thought they usually went at the fins....
