C8 LDS hydraulic oil Bleed Screw location?
Bunny
Unread post by Bunny »
I have trawled through the on-line manuals and downloaded that kindly uploaded by “GiveMeABreak” on the site but do not see a reference to where the Power-Steering LDS hydraulic oil Bleed Screw is located (or if such even exists).
Is anyone able to offer any help and guidance, please?
x 6954
Re: C8 LDS hydraulic oil Bleed Screw location?
There is no bleed screw Bunny.
To bleed the Power Steering Circuit:
  • Turn on the engine and let it idle for 2 to 3 minutes, without moving the steering wheel.
  • Work the steering slowly, going from lock to lock in both directions, about ten times.
  • Check the level when cold (engine off).
  • Top up to the maximum mark (if necessary).
  • Close the power steering hydraulic reservoir cap.
Caution You have an electropump fitted on your C8 - for these the correct fluid to use is Total Fluide DA link below as an example. You must NOT use AT42 or other fluid on these pumps.
https://www.ebay.co.uk/itm/161709755509
Bunny
Thanks.
The fluid I topped up with is Comma LDS and described thus:
"Lds fluid is used in suspension, power steering and hydraulic systems. This synthetic formulation can be used in all applications that currently require Psa S71 2710 in certain PEUGEOT, Citroën, DS, SSANGYONG &toyota models. Comma oil and chemicals was founded on a real ‘passion for performance’ in 1965 as a UK-based, independent oil 'blender'. quickly establishing their products as being the first-choice Supplier of engine oils to independent workshop mechanics in the UK, Comma has recently grown to distribute to more than 40 other countries around the world".
I note the fluid you recommend has the following specification:
"Specifications:
PSA S71 2710
MAN 3289
Renault PSF Class 1"
Is that OK?
x 6954
Yep, LDS fluid was the pre-runner to Total Fluide DA - I only used that name as it is the current name, so no problems :-D
jml
Locked user account
x 37
Unread post by jml »
Now I’m confused !!
I was looking to top up my PAS fluid on my 2008 C8 173 the other day and used Total’s Lube advisor.
It came up with Total XLD3 or G3 ! So, what should I use ??
Oddly, the outside top of my PAS reservoir cap has always been a little damp with fluid yet this is the first time in over 150,000 miles it has dropped to the Min. Any ideas ?
Cheers
Julian Leyton (RIP) 2023
x 6954
TOTAL FLUIDE DA.
You have to bear in mind the C8 had various power steering systems - some mechanical requiring different fluid and some electric (which is what yours is). You need Total Fluid DA. As usual, third party databases as useful as a chocolate teapot and they have got this totally wrong in that they have 3 types of the identical engine showing - yet fail miserably in distinguishing between them or the power steering systems.
The mechanical pumps used AT42 (but not for very cold countries or PENTOSIN CHF11S for very cold climates. For electro-pumps it is Total Fluid DA.
jml
Locked user account
x 37
Thanks Marc.
You'd have thought that, with Total being Citroen's preferred supplier, they'd have got it right !!
Btw I guess you got my PM the other day ?
Cheers
x 6954
Yes, apologies - have had quite a few to get through - I've just sent a reply :)
jml
Locked user account
x 37
Hi Anyone, but probably Marc :)
Sorry to drag this up again however I need to top up my PAS fluid just a little.
I see that the correct fluid for my electro hydraulic system is Total Fluid DA, however I see that LDS fluid was the pre-runner to Total Fluide DA.
I have some LDS fluid - will I be ok using that ?
Cheers
Julian
x 1919
Unread post by Paul-R »
LDS and DA fluid are currently made to the same specification. So, yes, fine to use LDS in place of DA.
jml
Locked user account
x 37
Many thanks for your quick reply. But it makes me wonder why Total bothered making both ??
Cheers
Julian
x 6954
Yes, they're the same Julian, both made to PSA S71 2710 specifications. I think as they began to use it for more and more of the power steering systems on PSA cars, and seeing as the 'LDS' name was synonymous with Citroen's later hydraulic suspension system fluid, they probably decided to change the name to break the link (and probably may have had something to do with the fact they had decided not to make any more hydraulically suspended Citroens after the C5 X7).
jml
Locked user account
x 37
Ah ha, that would make sense. Many thanks Marc and I wish you - and everyone else who helps on here - a Happy New Year :)
Cheers
Julian
x 6954
Thanks Julian, same to you and do keep well :)
jml
Locked user account
x 37
Just thinking about it, maybe DA stands for ‘Direction Assistee’ Ie Power Steering !!
