Citroen AX 1.1 water temp gauge
Brendan
Unread post by Brendan »
I'd like to fit a water temperature gauge to my Citroen AX.
Would one fit in the same hole as the Overheating Light sender ?
Thanks.
x 8069
Re: Citroen AX 1.1 water temp gauge
Hello and welcome to the forum. Assuming you already have the guage in mind that you wish to use then all you will need is a temperature sensor screwed into the radiator, quite possibley in the existing overheating sensor's hole. You can get sensors in various sizes, see
https://www.ebay.co.uk/itm/Aftermarket- ... qtxO3xSAVw
as an example. Just take out yours and measure it and away you go. Good luck :)
Brendan
Thanks for that.
Brendan
x 1438
Unread post by xantia_v6 »
The existing overheating sensor won't be fitted to the radiator (as it would be useless in the event of a loss of coolant). There is a good chance that the engine already has a hole for a gauge sensor, as the same engine would have been fitted to cars with temperature gauges.
If someone can pull up the correct parts listing diagram, all should become obvious.
x 1751
click to enlarge
This diagram is for carburettor AX, where both gauge sender (#10) and temp warning switch (#9) are fitted. The monopoint injection arrangement is similar.
Do post your VIN, and I might be able to hit exactly the right parts diagram.
x 1438
What you are looking for is either of the #11 in the diagram (there are 2 shown), they are blanking plugs that can be removed to fit a standard threaded sensor.
Brendan
Thanks for the diagram - it says it all!
The voltage changes according to the load (headlamps, heater blower, etc.)
Will this affect the temperature reading on the gauge ?
Brendan
x 8069
The temperature sensor is a thermister which is simply a device whose resistance changes with temperature. The car's voltage does not change significantly with load, it is the current drawn which increases with loading so the voltage across the thermister will be pretty constant, assuming the battery and alternator are in good health, then as the thermister warms up its resistance drops to allow an increased current flow in the guage circuit. This increased current causes a bigger deflection on the guage and thus shows a higher reading. If you have an electronic guage then its internals will convert the measured current changes to alter the reading. :)
Brendan
Thanks, MTM.
