XM 2.1 TD BOSCH PIPEWORK CABLES HELP PLS
NAMUR22
Unread post by NAMUR22 »
Further to my post on Peugeot maybe its better here LUCAS to BOSCH conversion , Thanks for all replies , yes the lucas was good but it starting leaking terrible and i needed a mot quick living in the sticks got to get to hospital doctors etc , i took top off bosch pump and it was pretty scabby inside locked sleeve , i forgot i had a new pump in a box ( bought on here ) so fitted that today yes bosch pipes and injectors , running good but still need to know a few things PLEASE , rear cable connector on pump what does that do , front cable connector to round silver tube with 2 water pipe connectors , top diaphragm connector i think goes to inlet manifold car not pulling well slight uphill , i disconnected lucas at pin unscrew now incorrect MPH and management light on , i should of taken pics of XM i took all gear off 2 years ago so lost track of pipe/cable work , i took engine alloy water pipe manifold on right side of oil filler and a small stub outlet i think goes on front of head by pump , Any answers appreciated in advance even 1 problem at a time i think my speedo and management light concern me most , Many Thanks
x 1438
Re: XM 2.1 TD BOSCH PIPEWORK CABLES HELP PLS
Unread post by xantia_v6 »
You may find this helpful:
CitroJim wrote: 18 Dec 2012, 14:29 The old Lucas ECU must stay in place as it drive instruments on the dash and controls the glowplugs. The EML will remain forever on until the bulb is removed...
x 1751
The Bosch booklet covering the VE pumps (there were three types) can be dowlnoaded here:
https://www.academia.edu/26805825/Diese ... nstruction
Bosch publication (part number) is 1 987 722 164, dated 1998/99.
NAMUR22
Thanks for Replies
