Can anyone tell me where the sensor that detects the external temperature for the LCD display is located?? My temperature display just repeatedly flashes "- -"
HELP!!!
Xantia VSX External Temp Sensor
pwatson
ZEGA
me_at_home
Hi, my L reg 1.9 td vsx has it behind the drivers side door mirror, remove the mirror glass,( wire clip on rear of glass which comes off upwards ) be careful as there are also 2 wires for the heater.
The sensor wire ( black on mine) goes into the car but I was able to cut it and resolder the new one on to the old wires.
The sensor is located into the bottom of the mirror housing and just pulls up from within the housing.
Hopes this helps[:)]
Best Phil.
Best Phil.
philhoward
me_at_home
