DS Owner Handbooks
x 6955
DS Owner Handbooks
If you don't have your DS owner's manual, you can view most of them online or in most cases download a copy as a PDF, or in some cases just the relevant section required.
Not all early models are included.
  • Just follow the link, select your preferred language from the top right corner
  • Then select the model
  • Now select the car image and finally the build date of your vehicle
Note: Be wary of the owners manual versions for left hand drive vehicles, which the following images circled in Yellow represent as an example.
These are searchable for content, and if they are available as a download, there should be a PDF icon shown. Click on this and it will either give you the option to save the file, or will open in a browser window. Once the file has loaded, you can save the file as a PDF to a location of your choice.
Bear in mind some of these can be 400+ pages for some newer models with loads of options, so may take a little while to download for some users depending on your broadband speed.
DS Owner Handbooks Link
Note: These are Owner Reference Handbooks for the Equipment and Operation - not Mechanical manuals.
TheBadger
x 5
Re: DS Owner Handbooks
Unread post by TheBadger »
That's a great link to be aware of, so thanks Marc!
Thought I'd mention there's also the iOS and Android "Scan MyDS" app available that provides basic information for key functions.
Neilied
x 6
Unread post by Neilied »
Thanks for the link. Did the DS5 come with a paper copy? Can these still be purchased?
Regards
x 6955
I have a PDF version of a 2013 manual if you want one that you can download. Let me know and I'll email it to you.
Iansel
x 7
Unread post by Iansel »
Mark,
Is it me or is the Handbooks link above broken? I get the page up but can't select language or vehicle.
Looking for a PDF of 2019 DS7
thanks
x 6955
They periodically take the site down (offline) for maintenance and updates - it's back up as of 10:10AM and the link is fine.
Iansel
x 7
Yep working again thanks Marc. Just unlucky with my timing.
