C6 Radio no sound
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
IpeXM
C6 Radio no sound
Unread post by IpeXM »
C6 radio lost its voice. Seems to work fine but no sound at all.
Checked fuses and took radio out to take connectors off and back again.
No help. Any suggestions? :)
x 6961
Re: C6 Radio no sound
Hi and welcome - please post up your VIN so I can determine exact options fitted - as it could be an amp issue (as a lot of these have factory amps or other). I'm consulting electrical diagrams so need specifics I can get from your VIN.
IpeXM
Ok, here comes.....
x 6961
Ok, so you have the RT3 Head unit and the equaliser Amp as I suspected - leave it with me while I check it out...
x 6961
Ok, so first thing is to check out the fuse to the equaliser amplifier. I would check it with a multimeter and not just a visual check as these can burn out at the edges being hard to see.
It is in the passenger compartment fuse box (BH12) and is a 25 Amp fuse, F32 as per the diagram - should be fourth one up.
x 6961
Next if you have a Lexia, run a diagnostic check on it. If you are getting an FD3A fault code then that is an internal amp fault causing:
  • Malfunctioning of the audio adjustments
  • No sound
  • Malfunctioning of the adjustment of the sound quality of the equalisation effect
  • Loudspeakers randomly cut out
  • Impossible to put on MUTE
The fault can be with the AMP itself or the electrical wiring.
The system detects any occurrence of an internal error (Memory, processor…) Every 1.5 seconds (for a HARMAN model) or every 200 ms (for the PHILIPS).
IpeXM
Thanks,
Have to measure fuse first. Last time just took it off to see if broken.
I try ask if I can borrow Lexia from someone :-D
All the functions are just normal except volume knob in radio.
That does not work when you turn it. From steering column push buttons
are working.
Rgds,
Ilppo
x 6961
So are you saying you have volume control when using the remote buttons?
IpeXM
Yes in that way everything seem to be fine but no any sound.
Just measured that fuse and changed a new one.
Noticed there is no power in that slot (0,5V).
Is there some relay providing power to amp?
IpeXM
Oh.... was wrong about the power. It's ok:)
Had too thick contacts in multimeter.....
x 6961
I'm just putting together a schematic for you...
x 6961
So as you can see, the Amp power is via F32 as per my last post and this in turn is supplied my Maxi Fise 3 (MF3) in the engine fuse box.
But MF3 also supplies power to the Cabin Fusebox supply (BH12) - as we know, the front RH heated seat, the radio amplifier (F32), the Hydraulic Suspension ECU and the AM6 automatic gearbox. So if there was a problem with the supply, it would also affect these other systems.
So if you have no sound via the Head unit volume button and no sound via the audio remote on the steering wheel, then either the amp is faulty or the Head Unit - so you really need to get Lexia on it and do some tests / fault code readings.
8480 is the RT3 Head Unit
8408 is the Equaliser Amplifier
IpeXM
Thank you:)
I try to get one used head unit and try first with that one.
Think still need to "code" used one for my car.
-Ilppo-
x 6961
Yes you will need to VIN code the new unit - if you can locate a used one - they are very hard to source nowadays.
IpeXM
Hi
Got a used radio and installed it but still no sound.
Where is that amp located in C6?
Could not find it:)
Ilppo
