Citroen Ax/mot failure
xantiagreen
Unread post by xantiagreen »
L973 UCM - Citroen Ax
Looking to buy this car but has a host of issues on MOT failure 22nd June 19, need advice as the bottom coolant hose has failed and mot then passed and failed a yr or 2 later is this a common fault.
There are also quite a few areas that need new panels how easy is it to get front both side under bonnet panels and front wings. It has 50k and i think its a 1 owner.
I bloody miss my xantia
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
x 1987
Re: Citroen Ax/mot failure
Unread post by Stickyfinger »
Lots of Clean (of rust) AX's about....
Sloppysod
x 386
Unread post by Sloppysod »
Looking at the failures documented as taken from the .gov https://www.check-mot.service.gov.uk/website does not seem too bad, yes it appears they had to stop due to coolant loss and there could be other faults. As it has only done 1,325 miles since last MOT and all the work on the last MOT would/should have been done I think you may be on a winner, for another year at least, depends on how much you pay - question to ask it how much would it be worth scrap to the current owner! (<££/£££)
Repair immediately (major defects):
  • 1, Nearside Front passenger door does not latch securely closed (6.2.3 (a))
  • 2, luid leak harmful to the environment or a risk to other road users coolant anti freeze (8.4.1 (a) (i))
  • 3, Emissions not tested excessive coolant leak at time of test (8.2.1.2 (d))
  • 4, Parking brake efficiency below requirements (1.4.2 (a) (i))
Monitor and repair if necessary (advisories):
  • 4a, Rear Service brake requirements only just met. It would appear that the braking system requires adjustment or repair (1.2.1 (c))"
So going forward.
  • item 1, adjustment would be a good place to start, possibly just all gummed up and needs a clean,
  • item 2 you know about,
  • item 3 ?
  • items 4 & 4a would probably be dealt with together, either by adjustment of new shoes.(Pads?).
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
xantiagreen
Not had time to look at the Ax as the replacement for the xantia I sold has a jippy tummy...
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
