Berlingo 1.8i Stalling when cold.
filber
My Berlingo Multispace stalls 30 sec after startup. I can keep it running with the revs running at 2000 untill warm then it drives okay. If I drive off before it has warmed up it will stall everytime I brake. Any info for correcting this irratating behaviour much appreciated thanks
AndersDK
To me it seems to be a choke problem - as it's exactly at cold engine - never on hot - you have the problem.
The engine management (ECU) has it's own Coolant Temp Sensor (CTS) exactly to decide your engine's working temperature - and uses this sensor to decide fuel enrichment at cold engine.
Either this sensor is defective (shortcircuit) - or it's 2pole plug and/or cable may be at fault. The fault would be one of the leads in the twin cable earthed - or the cable/connector is shorting out.
The CTS is located near the thermostat housing - but you may also have a similar looking 2pole sensor for any temp gauge & overtemp warning light fitted.
Try locate any 2pole sensor connector fitted as described - then with this (in case 2 found : both) connector UN-plugged start the COLD (!) engine.
If your engine now runs perfect at cold - then the connector re-fitted making the engine run bad again (connecting one at a time) - is the (bad) CTS.
If no change detected on this test - stop engine and try trace the entire (both) cable run for any cable damages.
