Did replace ignition switch unit while back so got fan etc to work and green light came on also.
Is there a normal Citroen Gremlin for it
Will when sort Trolley jack out as one i have has a lift cup size of a large town which jacks up either end of car missing jacking point!(Modding it with a 150mm rubber and disc of steel so sills safe from it) then turn compressor make sure not seize? but not hearing click anyway.
Would it be relay or fuse?
