bleed nipples
froggy
(Donor 2026)
x 4
bleed nipples
Unread post by froggy »
Hi, my S1 Xantia needs some new rear , bleed nipples. They are badly worn, is this something that I can get off the shelf( if I knew the thread size) or is it Citroen only? thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1751
Re: bleed nipples
I think they are M8 thread, with a 90° tip angle.
Part number is 1210 06, but NFP (no longer available) from Citroen.
Same part used on BX, C25, Xan I and II, XM I & II.
You should be able to get hold of some from a motor factor.
Using a flare nut spanner (single hex) prevents these from getting worn...
x 3299
Re: bleed nipples
I would also dose them daily (for a week) with Plus Gas, to help free them up.
x 1240
Re: bleed nipples
Unread post by Peter.N. »
Try ebay.
van ordinaire
(Donor 2017)
x 402
Re: bleed nipples
& get stainless ones - so you never have this problem again: they don't get enough use to wear - but they are very vulnerable, & will virtually rust away.
Freeing agent of choice is a given, removal tool of choice has to be a good quality 1/4 drive, walldrive socket & a fine ratchet.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
