Hi need your help. Have a citroen c2 vtr 1400. It starts fine and idle fine, everything is fine while driving, revs is normal while driving
And stationary. Here is the problem. After driving and stopping at the shops, if you then start the car the idling jumps to about
2000rpm for about 30 seconds or more then dropping back to normal. This only occours after driving and the car is warm and at start up.
Have change the MAP sensor, the throttle body and checked for vacuum leaks. Change the plugs and cleaned the filter. It did give me an P1108 code saying
MAP sensor.
Could it be a O2 sensor or a leaking injector. There is no engine lights on. The fuel consumption did increase.
Do you have any advice, please
