Citroen C2 AT problem.
rabee7878
Unread post by rabee7878 »
Hello brothers.
I bought a car (Citroen C2 2009) with a problem in the controlled manual gearbox and this problem only appears in the third gear, and sometimes it works normally, I did a detection and showed me this error (P0750 Vehicle with TU1M+ Engine the gear does not engage) in the diagnostic device, what is the correct procedure to correct the problem ,, i tried to program the gearbox by (Lexia) but the problem is malfunctioning It appears from time to time.
Vehicle:C2 VAN
Engine Type:NFU
Year: 2009
Thanks to all
x 1043
Re: Citroen C2 AT problem.
Unread post by wheeler »
First thing to do is to carry out a reprogramming procedure on the gear change & clutch auctuators again.
Anytime you do this you should have another running car connected to the battery with jump leads, if you dont do this i find the procedure almost always fails as the procedure is very power hungry & causes the battery voltage to drop too low.
rabee7878
wheeler wrote: 23 Jul 2019, 19:10 First thing to do is to carry out a reprogramming procedure on the gear change & clutch auctuators again.
Okay i will try to program again with external power charge, thanks a lot.
