C4 Grand Picasso tracking data
pauljordanie
Unread post by pauljordanie »
2009 C4GP 1.6HDI DV6TED4 Does anyone know what the front wheel tracking angle should be on one of these please?
x 6954
Re: C4 Grand Picasso tracking data
Here you go:
ApplicationValues
Camber : Left-hand wheel (not adjustable)0° (+0°40' ; -0°20')
Camber : Right-hand wheel (not adjustable)0° (+0°20' ; -0°40')
Castor (not adjustable)+4°54' (± 0°30')
Pivot angle : Left-hand wheel (not adjustable)+11°42' (+0°20' ; -0°40')
Pivot angle : Right-hand wheel (not adjustable)+11°42' (+0°40' ; -0°20')
Tracking at the axle (adjustable)-0°21' ± 0°09'
Tracking at the wheel (adjustable)-0°11' ± 0°04'
Camber dissymmetry+0°20' (± 0°28')
Castor dissymmetry0° (± 0°20')
Pivot angle dissymmetry-0°20' (± 28')
pauljordanie
I had NCT (MOT) test done last month. One of the readings was wheel alignment/slip test. Mine had a reading of 8m/km. I have excessive tyre wear on the inside edges of both tyres, the offside one is worse, and I go through a set every 20,000 kms. The rest of the tyre is untouched. Does the sljp test reading indicate tracking is out? When I get new tyres I always have 4 wheel alignment done.
