Xantia HDI Timing / Aux Belt Kit Recommendations
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Hi all
Been a while since I posted!
So as a precaution I'm looking to replace my timing belt (10 years old now) and the auxiliary belt (?? years old) along with the water pump & tensioners etc.
Could anyone recommend manufacturers for each kit that is as close to OE as possible? Have seen kits from Bosch / Febi / Dayco / INA / Gates / Conti amongst others.
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
jvwykes
x 11
Re: Xantia HDI Timing / Aux Belt Kit Recommendations
Unread post by jvwykes »
Hi
I've done this job several times. Last time I bought a kit with belt, water pump and tensioners made by Gates who are OEM. Dayco are also one to be recommended
good luck
sparksie
x 33
Unread post by sparksie »
Seconded.
Never had a problem with the Gates kit. Well, not on a PSA engine, anyway.
Sparksie
2000 Xantia 1.9TurboD
x 1460
Unread post by xantia_v6 »
PSA used several suppliers for the original belts, including Gates and Dayco.
Raul
Unread post by Raul »
I am going to do the same job on my berlingo 2.0 hdi. I am going to find out how much they ask for an OEM kit and if it is not so bad then I am going with OEM kit. And also with OEM water pump.Also what do you think should I also order new OEM bolts for tensioner , roller and crankshaft pulley. I have heared that sometimes the tensioner roller bolt has snapped during reuse( maybe using wrong torque?).
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
XantiaExclusiveHDI
Thanks guys
I'll look into the Gates & Dayco kits :wink:
Currently:
Previously:
BX 19 TZD Turbo
XantiaExclusiveHDI
OK - Gates are showing one kit for the timing belt & pump with a part number KP15524XS.
However they are showing three different kits for the auxiliary belt for HDI 110 cars with aircon:
K056PK1735 - Sanden
K026PK1750 - Delphi
K016PK1745 - Delphi
How can I find out which will be the one for my car?
Currently:
Previously:
BX 19 TZD Turbo
x 3306
If you were to post up the VIN (which will, for security reasons, be obscured so only Moderators can read it) a Moderator can then look up what your car had when she rolled out of the factory, including the A/C equipment.
XantiaExclusiveHDI
Thanks Hell Razor5543
I have my VIN, will it be automatically hidden or is there a way to make it viewable only to moderators on the forum?
Currently:
Previously:
BX 19 TZD Turbo
x 3306
It will automatically be obscured so that ONLY Moderators can read it.
XantiaExclusiveHDI
Ahh OK :)
The VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Currently:
Previously:
BX 19 TZD Turbo
XantiaExclusiveHDI
I have two part numbers now, and it depends on whether the AC compressor is a Sanden model (part no: K056PK1735) or a Delphi model (part no: K026PK1750). Is there any way to tell?
Currently:
Previously:
BX 19 TZD Turbo
XantiaExclusiveHDI
OK - the part number cast into the compressor casing is 6560502. I think on research this is a Delphi compressor. Can anyone confirm? This would suggest I need belt K026PK1750
Currently:
Previously:
BX 19 TZD Turbo
x 6957
For your VIN, there can be either type of compressor fitted:
Delphi Compressor Citroen Part No: 6453AQ, Delphi 1135290
Sanden Compressor Citroen Part No: 5453TK, Sanden SD7V16 QA1106 and SD7V16 QA1227
As for the belt:
If Sanden Compressor Fitted: K6-LE1736 (Citroen Part: 5750YF)
If Delphi Compressor Fitted: K6-LE1750 (Citroen Part: 1606353780 or 5750YG) Both these are still available from parts.
XantiaExclusiveHDI
Thanks Marc :)
Having wiped off some grime I found the part number on the label which is 1135290, so it's a Delphi :)
Better get ordering the kits and work myself up to the job in hand 8-[
Currently:
Previously:
BX 19 TZD Turbo
