308 1.6 petrol engine rattle
Richie Daniels
Unread post by Richie Daniels »
Hi guys , my son has a pug 308 1.6 petrol
When it’s cold the engine rattles like hell
When it warms up it gets much quieter to the point where it almost disappears
The dealers have quoted nearly a grand for complete timing chain assembly 😮😡
A friend of mine said just replace the tensioner on the outside of the engine after a flush and oil change
The car is four year old with 24 thousand mile on it
What do you think ?
Many thanks
Richie .
x 1438
Re: 308 1.6 petrol engine rattle
Unread post by xantia_v6 »
Please post your VIN, so that we can see exactly which engine variant you have, and the manufacturing date. The timing chains and tensioners on these engines were very troublesome and there were several design changes to improve the reliability. Most of the common issues were however sorted by the time your car was built.
Does the car have a full service history of oil and filter changes?
moizeau
x 429
Unread post by moizeau »
With correct oil?
Pete
Richie Daniels
This rattle is not present at idle or constant engine speed , only present when revving and engine speed running back down to idle
Hope this helps
moizeau
x 429
Sounds like a tensioner.
Pete
Richie Daniels
Was the tensioner
Got one from dealers , over a hundred quid.
The old one appeared to work but on closer inspection the oil galleries were blocked
Happy days , thanks for all the advice .
