Is there a live supply at the rear of the DS5 that supply 12v when reverse is selected? Not by splicing the rev wire.
David19
I have just brought a DS5 auto that does not have a reverse camera, is there a plug point that a factory fitted reverse camera would plug into at the back so I can utilise the signal for a third party camera?
- x 6950
Re: Is there a live supply at the rear of the DS5 that supply 12v when reverse is selected? Not by splicing the rev wir
They tend to have a specific rear harness that the camera module and mini wiring plugs into which goes back to the Parking Assistance ECU and then onto the BSI and Head Unit. The parking assistance ECUs are specific dependent upon options.
David19
12v supply from rev light
DS5 1.6 THP Performance Line, need to splice into the rev light wire to send a signal for my third party rev cam, I have a specific relay for can bus system it worked fine on my C4 airdream - anyone know if it should work on my DS5?
Reason: Topic Merged with your previous one about this.
