Hi.
I'm about to scrap my C5 but it's got a full tank of petrol. Anyway l can get it out easily? I tried sticking a hose pipe in the tank and sucking but nothing much happening (and probably not the smartest of ideas)
Remove petrol
- x 1473
Re: Remove petrol
The usual method is to use the normal pump in the tank to pump the fuel out. The trick is to find an accessible hose to run into your can. If you put the gear selector into D (I assume that it is an automatic), then turn the key to the start position, the engine won't turn over, but the fuel pump should run.
Re: Remove petrol
pinheadplanet wrote: 11 Jul 2019, 17:43 Hi.
You're not wrong there!
Tell the scrap man there's a tankful and ask if he will pay a bit extra for it. They are set up under the environment regulations to gather all pollutants before crushing/breaking, usually they put a catch tank under the car and put a pick axe through the bottom of the tank.
You could do your hose trick if you know how but you might be playing with fire--literally. Alternatively you could attach an electric pump to the pipe under the bonnet and pump it into jerry cans.
Take great care petrol's nasty gassy stuff especially on hot days.
Michel
Re: Remove petrol
In this weather, to be frank, try and get the scrappy to give you a bit extra or forget about it. It's not worth the risk unless.
Diesel - yes. I recently drained a full tank out of a Xsara Picasso, but I'd have not bothered for petrol.
