Morning Forum,
The A/C in my 2002 citroen synergie is not working had it re gassed yesterday but still to no avail.
The compressor has power going to it but the clutch is not engaging at all, before i start to shell out hundreds on replacing the compressor i was wondering if anyone knew the location for the A/C relays i thought i may change them first and see if i get any joy.
any indications or help would be greatly appreciated.
tony
citroen synergie A/C not working
- x 3296
Re: citroen synergie A/C not working
Before swapping any parts might I suggest you first see if you can arrange for a Lexia diagnostics session? This should narrow down what the actual fault is. There are Forum members who have Lexia clones and are willing to help other Forum members;
viewtopic.php?f=19&t=56452
- x 6946
Hi Tony, unfortunately I don't have a circuit diagram for this model - only the Automatic Air Conditioning System, not the Single Air Conditioning that you have on your Synergie.tony1976 wrote: 11 Jul 2019, 07:06 Morning Forum,
tony
On the Auto A/C version the Compressor cut-off relays are controlled by the Engine ECU and the Coolant Temperature unit. But as you have single A/C - it will be a lot simpler I suspect, but no idea where it is.
