Citroen ZX 1.4i Pazazz, Map sensor
Boomer
Could someone please tell me were the map sensor is located, Contacted the dealer, they say it is on the drivers side inner wing, but it isn't. I've also checked round the inlet manifold but nothing.
noz
CITMAN
The dealer says that its on the inner side wing. It was when the car came out of the factory its towards the front of the engine and has a black cover over it and is near the throttle cable, so in theory you can follow the cable and be able to see as there is a rubber pipe going to the throttle body. But there was a problem with petrol and oil getting into the map sensor itself. So the mod was to move the sensor to the drivers side suspension turret, so that pipe is inclined slightly so that oil and petrol can drain off. You can trace the little rubber pipe from the single point injection unit to the map sensor.
alexx
CITMAN
alexx
Citman,
well, it turned out several times, that data in Haynes were not always accurate ...
I found another info (www.obd-2.de) - ZX 1.4 from 1996 on can be also fitted with Bosch Motronic MP 7.3 (it's a multi-point injection, I think)
How did you find out that your MAP needs replacement, how did the engine behave? I have a slight problem with my Xantia (Sagem SL 96 injection). When you press the throttle quickly, there's a little delay (about 1/4 of second) in engine response, so this is a bit annoying. There are no other problems (idle is stable, performances ok). Diagnostic device didn't show any errors and all sensors were giving 'normal' readings.
cheers
cheers
Boomer
Boomer
alexx
According to some spreadsheets I have here from various noname sources, KDY is indeed fitted with Bosch A2.2. So, if info about A2.2 in Haynes is correct, there's no MAP sensor. CPU type should be stamped somewhere on the unit. Also, if I remembered correctly, this type of fuel injection doesn't control ignition, so there must be ordinary distributor on the engine, unlike MA3.0 (KDX engine).
Boomer
THANKS FOR THE INFO ALEXX, bUT AS U CAN SEE FROM THE PHOTOS IT IS A DISTRIBUTERLESS IGNITION.HTTP://WWW.MTBDERBYSHIRE.CO.UK
Sl4yer
CITMAN
I can guarantee that the KDX has a MAP sensor. When mine went it misfired as it was overfuelling, sooting up the plugs. The second time it was same but ten times worse, in the middle of wales, miles from civilisation, juddering, misfiring, cutting out, no power, which cleared for a bit on turning the engine off. The car did get us home though (150+ miles).
A citroen specialist put it on his diagnostic machine, and it said the map sensor was recorded as the fault. Since it was replaced no further problems.
When was you pzazz last serviced, it might be dodge leads and plugs. Failing that it needs to go on a diagnostic machine to sort it out.
alexx
Boomer, nice pictures.
Well, I didn't own any ZX, but some additional info here may be of some help. Your engine is defo different than the one in Haynes, which is clearly KDY (ID plate is visible on one picture):
- your is distributorless, while that one in Haynes has distributor and different ignition coil, with one output (like in BX I owned before)
- your hasn't ignition retarder, which should be situated behind the battery
- throttle housing is a bit different
So, fuel injection in your car obviously isn't A2.2, but probably MA3.0
Citman, did you actually check, that you have MA3.0. According to spreadsheets I have, KDX engine can be also fitted with Magneti Marelli G6 injection, which does have MAP.
Picture of Magneti Marelli MAP, along with datasheet, can be found here: http://www.magneti-marelli.com/sensors-pressure.asp (I think it's PRT 03/04)
Stuart McB
Map sensor. About the size of a small box of matches, quite thin with plastic tube comming from the bottom and a multi plug on top looks as it may be made from half plastic and half metal and black in colour. Bolted to the inside if the drivers wing by the power steering fluid. Held to the wing by a 6mm bolt (10mm head). remove plug and tube undo bolt and its off. Easy fix as expensive to buy. place on a radiator all night with paper towle under where the tube should go let old oil residue dripp out then re fitt, the car should run better. If you need to by one get the yellow pages out and speak to a BOCSH specialist as I think if memory serves me well £50 from Bosch or £125 +vat from Citroen. The stalling is a classic sympton of MAP sensor on these smaller engines. Took me about 3 months to figure it out after numerous trips back to the dealer with my Xsara VTR 1.6.
Boomer
