2.0hdi 57 plate dispatch, dies then won’t start
Christian rocky1
Unread post by Christian rocky1 »
Hi my van started fine then I reversed up and it died and then wouldn’t start so I squeezed the primer pump and push the accelerator and it started? It has done this two days running now 😩 any help would be appreciated 🙏🏻
x 1240
Re: 2.0hdi 57 plate dispatch, dies then won’t start
Unread post by Peter.N. »
Probably a leak in the fuel system somewhere. Have you changed the filter lately? If so make sure its sealing properly, if not change it.
Christian rocky1
Thanks Peter, I have only owned the van 2months it was supposed to have been just serviced. It has been fine until the other day, it seems to be once it’s left for a few hours it starts then dies after a few seconds then won’t start until I have primed the fuel pump?
