207 gear oil level check
doctle
x 226
Unread post by doctle »
Another pothole another pair of shocks to replace. This time I wasn't concentrating and I lost a little gearbox oil. I'm not sure how much so I will need to top it up. The box is top filled under the battery so does anyone know a way to check the oil level on these? It was replaced in March.
Oh buggle
jsp
x 12
Re: 207 gear oil level check
Unread post by jsp »
I guess its a manual. These don't have level plug anymore. how much did you loose measure that and refill amount with it.
doctle
x 226
Yes it's manual and I didnt lose much, but it went on the floor so now way of measuring it and it's been covered with fullers earth now anyway. When I drained it in March there was 1L in it but I'd say a lost 200 mil at the most. My nearest Peugeot dealer is 40 miles away so I'll have to drive there if possible.
Oh buggle
x 6963
For your info - as they are 'sealed for life', in the event of a leak they recommend a drain and refill to get the correct level - see warning below
Capacities:
Quantity of oil to fill after draining: 2.1 ± 0.1 litres.
Quantity of oil to fill after an overhaul: 2.2 ± 0.1 litres.
Oil quality: 75W80.
CAUTION: It is necessary to drain the gearbox and put back the exact quantity of oil, in the event of an external leak or a repair.
doctle
x 226
Thanks Marc I suspected as much, my carelessness so I will get it sorted tomorrow.
Oh buggle
x 1751
75W-80 GL4 gear oil (and not GL5 or 4/5), eg Total Transmission 8.
doctle
x 226
Yesterday I drained the gearbox oil there was 1.7 litres in the box. I added 1.8 litres and when I was replacing the battery noticed the copper seal off the bung was on the ground. I had to sacrifice the wife's baking bowl as I had nothing clean enough to catch the oil in. She wasn't impressed. I suppose I'd have got away with the 1.7 anyway.
Oh buggle
x 3283
I would have used a new crush washer, to ensure a good tight seal. Copper washers can (over time when in contact with a hot surface) harden up and then not provide such a good seal when reused.
