Some on here may remember my ups and downs with the afforementioned beast!
The hot cutting out issue was definitely fuel pump
I've also fallen foul of the turbo inlet pipe creeping off and causing extremely rough running, bad starting, e tc,
Also, I found some horrendous bodged wiring by the 2 fuel pump relays and have replaced the relays As well
When the car runs well it is lovely now, strong, fast smooth. BUT, it STILL has an intermittent fault, it will sometimes start to hunt, and then the revs will rise slightly and then it will be very hard go pull away smoothly, needs a lot of revs, and runs very rich. I'm pretty sure that when this happens, the turbo boost vague moves from it's middle stop and moves slightly to the right....
Oh, and I've also replaced the fuel pressure regulator
Thinking caps on again!
Update. My Gti Turbo
CGATCX25GTITURBO
- x 16
Re: Update. My Gti Turbo
Throw the plugs away. Start with fresh plugs check the ignition circuit coils and leads if you haven't. Check the gap on the flywheel sensors.
Has - had it had a clutch recently?
I've seen the slug on the flywheel damaged and cause issues
Does the boost gauge move to a positive? Could be map sensor related, vac hose off etc.
Does the tps work okay?
Are the three wires connected properly, might need to look at the Haynes BOL a d check the pin out back to the ECU.
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
