Citeoen c2 1.1 missfiring problem
Glupco555
Unread post by Glupco555 »
Hi I have c2 1.1 with sagem ecu, the problem is that when you drive the car more than 4-5000 rpm it goes like in limp mode and you need to wait a while for the car to start going again. The codes on diagnostic are p0300 and p1336. I have put new spark plugs, coil and crankshaft sensor. Do you have any suggestions?
