Lifting up Citroen Xsara
40075trip
Unread post by 40075trip »
Hi guys!!! I got Citroen Xsara 1.8 liter engine manual Xu7jp4 engine, year of 1998.
I love my car so much that we are going on travels together, countryside, gravel, snow in the winter, etc...
I would like to lift up the car a little bit, something like 5 cm, but I don't want handling to be very bad.
Basically lifting up the front is pretty easy, new longer spring with matched shocks and that's it.
The rear sus is the issue. what do you think guys which set up is the best?
Has anyone done it and knows about the handling is affected?
Thank you 😊 🙏🏽
Isaac Mor
Will Go To a Journey Around The World With My Xsara Next Year. So far working hard :P 8-)
dave_xsara
(Donor 2021)
x 10
Re: Lifting up Citroen Xsara
Unread post by dave_xsara »
If you haven't refreshed the rear bearings, now might be an ideal time to do it. You could get a refurbished rear axle and request the person doing the work to set it up for an increased ride height or you could follow the following guide:
https://pscuk.net/threads/59979-205-306 ... ow-I-do-it
x 1944
Unread post by Paul-R »
I fitted a set of rear spring assisters (extra small springs) on our Xsara Estate. It perked up the back end and increased the load carrying capacity.
http://www.springassisters.co.uk/
I fitted a similar kit to our new 308 as well.
