C5 X7: batery voltage increases when gas pedal released
marsalek
x 19
Unread post by marsalek »
Hi guys, I observed a "strange" battery voltage increase during driving, when I released the gas pedal. The voltage went within 1 or 2 seconds to 14.8 Volts. When idling or cruising, the voltage is around 12,6 Volts.
1. The voltage of 12.6 seems quite low to me. Normal alternators are charging the battery to 14.1 V or even more, based on the temperature.
2. The voltage increase is a clear sign of energy recuperation. This is nice :-) I heard of C5s years ago, that they missuse the generator (or the starter?) to help the combustion engine when accelerating from 0. Is it true, is there anything known about that?
Nice regards
Karel
Xantippa
x 29
Re: C5 X7: batery voltage increases when gas pedal released
Unread post by Xantippa »
That´s normal for HDi240, alternator "works" mostly when deccelerating, this is for saving fuel.
Kennyd90
x 5
Unread post by Kennyd90 »
My 2011 C5 x7 with the 163hp engine does the same.
