DW10td fuel system
Uberderv
DW10td fuel system
Unread post by Uberderv »
Hi everyone,
I have a strange problem when starting the car. If it's been left overnight or longer it will be a reet PITA to start unless I cycle the intank pump a few times. I can hear what sounds like bubbles when doing this.
My first thought is that the system is allowing the fuel to drain back to the tank via a leak but as of yet I have not seen any evidence when it's under pressure.
Any help or ideas would be much appreciated.
x 5634
Re: DW10td fuel system
Have you checked the leakoff pipes?
Uberderv
No, I assumed that as its post pump (HP) they wouldn't affect the feed side of it but I'll have a look thanks.
