Good afternoon all.
I’ve been meaning to get my cam belt done for a while, but was putting it off due to cost!
The cam belt has now gone and I’ve had the car towed home. I’m wondering if it’s a job that can be done at home in the garage? Especially if I buy a new cylinder head.
Whilst I’m at it I need to do the rear passenger spring as it’s corroded and I’ve got a small gearbox leak, so a new seal is needed there!
It’s a 1124cc model which I believe is better than having the cam go on a 16v model!
What do you guys suggest?
Citroen C2 cam belt has gone
- x 1056
Re: Citroen C2 cam belt has gone
It really depends on your abilities, as far as cylinder head removal & refitting goes TU engines are probably one of the easiest ones you will do.
