Citroen XM front seats
morna
Any one had a problem with the electric front seats only wanting to go in one direction? (flat for the RHS and upright for the LHS) The relay under the RH seat appears to be permantly energised when the ignition is switched on.[:(]
AndersDK
noz
Morna,
Had this exact problem with mine. It seemed like the seat had a mind of it's own, much to the other half's annoyance.
The problem was that the part of the seat which you sit on had come apart from the main part of the seat. It had moved forwards and was leaning on the switch. If it leaned hard enough the switch would operate and the seat would move. This would happen randomly depending on how much of the passengers weight was on that part of the seat at the time.
I pushed the sitting part of the seat back into place and secured it in position. The problem has never returned.
Sometimes the easy things just pass you by.
best of luck
cheers
noz
best of luck
cheers
noz
